1 members (Rich'sToys),
131
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | Guys, thanks for all the help, maybe one day I'll be the one Answering questions.
Intake/Exhaust manifold gasket going on, Gasket is paper (one side), Metal (other side).
2 questions.... Which side (of gasket) faces the Block? Do I spray "Spray-a-gasket" on metal side? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | You forgot to tell us what your working on.🛠Not everyone reads all your posts, so tell us each time. Thanks
| | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | '53 (full press) 235, Gaskets between manifolds & head
Thanks, Jim | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I am assuming a 235 or the like chevy. Metal to the outside. You could also use a rimflex gasket. Excellent at sealing the intake and exhaust, one piece. I have never had to use any other sealant on the stock gaskets and absolutely none to be used with the rim flex gasket. https://www.summitracing.com/parts/...d0Zf52QIVnYuzCh0ILwvYEAYYASABEgLctvD_BwE
Mike
