8 members (Keepinthemstockm, TUTS 59, Wally / Montana, Jay R, papas52, Otto Skorzeny, JW51, Gdads51), 95 guests, and 2 robots.
Topics128,084
Posts1,056,333
Members48,442
#1259242 03/19/2018 6:15 PM
Guys, thanks for all the help, maybe one day I'll be the one Answering questions.
Intake/Exhaust manifold gasket going on,
Gasket is paper (one side), Metal (other side).
2 questions....
Which side (of gasket) faces the Block?
Do I spray "Spray-a-gasket" on metal side?
You forgot to tell us what your working on.🛠
Not everyone reads all your posts, so tell us each time. Thanks
'53 (full press) 235,
Gaskets between manifolds & head
Thanks, Jim
I am assuming a 235 or the like chevy. Metal to the outside. You could also use a rimflex gasket. Excellent at sealing the intake and exhaust, one piece. I have never had to use any other sealant on the stock gaskets and absolutely none to be used with the rim flex gasket.
https://www.summitracing.com/parts/...d0Zf52QIVnYuzCh0ILwvYEAYYASABEgLctvD_BwE
Mike
