1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#125917 05/02/2007 7:46 AM
I recently did some welding in my dump bed. I had the cab covered but some dewberries got thru and landed on the cab. When I painted the truck I used Dupont Chromabase with PCL Superpro clear. It has been color sanded and buffed. The dewberries caused little divets, burns in the clear and down to the white paint that are about the size of a pinhead. (I know. I'm a pinhead for doing this). My question is, can I dab a little color on that divet, dab on some clear over that and try to smooth it out to blend flat with the original clear coat?
#125918 05/02/2007 8:47 AM
That's what I've done in the past. I'm not patient enough to get it perfect, but I've seen guys do it so you couldn't tell it was repaired with the naked eye.
Paint & Body Shop moderator
#125919 05/05/2007 12:59 PM
I agree with 4onthe.Toothpick, if anyone can see them, their to close to anyway.
#125920 05/05/2007 3:52 PM
Ha! Get away from that truck! Stand back! And while you're at it, take off your glasses!
Toothpick is a good tip. Any other techniques that have worked for anyone?
#125921 05/05/2007 7:03 PM
Paper matchsticks also work well for touch up
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
