Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Bill Hanlon, Otto Skorzeny, Gdads51, Cosmo, MickeyP), 59 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#1259170 03/19/2018 1:44 AM
I am ready to put the flywheel back on; the locking tabs that go under the flywheel bolts are in bad shape. Can i get them somewhere or is there something else I can use?
Should I use a loctite? which is best? can I replace the tabs with star washers?
evac34 #1259172 03/19/2018 1:53 AM
I like to use star washers with the serrations on the inside- - - -less likelihood of getting an oil leak onto the clutch since the flywheel bolt holes go all the way through the crankshaft flange and bypass the rear oil seal. Blue Loctite is also a good idea, since it seals the thread as well as keeping the bolts tight. A properly torqued bolt doesn't need a lock washer in the first place, and one that's not torqued correctly will loosen up no matter what kind of lock washer or tab is used.
