5 members (Otto Skorzeny, Barnfind49, Oldcaliforniakid, kades51, 1 invisible), 65 guests, and 1 robot.
Topics128,050
Posts1,055,671
#1258419 03/12/2018 6:40 PM
My quest is over, Eastern Surplus & Equipment has 20 inch 6 bolt stud centered military surplus rims in stock to fit my ‘56 C65.
danzimbric #1258556 03/13/2018 11:43 PM
Do you mean a 56 6500 series ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
danzimbric #1258822 03/16/2018 10:14 AM
Yes, they just arrived yeasterday. Nice rim with tire that has 70% tread for $130/ea
Are there any restrictions running military tires on the highway? Do they meet DOT requirements?
danzimbric #1258842 03/16/2018 1:28 PM
Look on the sidewall of the tire. If DOT approved it will say so. secret
danzimbric #1258859 03/16/2018 4:27 PM
Military tires with the cross bar type tread are meant for off-road use. They have a nasty habit of spinning a vehicle out if somebody spits on the street three blocks away. Make sure you have good liability insurance coverage before you go out in the rain.
danzimbric #1258871 03/16/2018 6:02 PM
Moderator
Moderator
2 Offline
Jerry is correct, I have a full set of DOT approved military tires on a 4x4 dump truck.
They are not good road tires.
Off road, not that good either, on a 13,000 lb truck unloaded.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
danzimbric #1258874 03/16/2018 6:39 PM
Insomniac
Insomniac
I remember driving a Jeep with non-directional combat tires down I5 in the pouring rain. We didn't think about how bad the tires were for freeway use. I suppose that's why the vehicles had governors restricting us to a max of 55 mph!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
danzimbric #1258898 03/16/2018 9:59 PM
Good to know, any potential problems running a mix of military and dot on the rear with dot tires on the front with both sides are equal on the rear (1 mil and 1 dot on each side)?
danzimbric #1258910 03/16/2018 11:11 PM
Mechanically no. Legally yes. Non DOT tires run on public roads can get you a hefty fine if caught.🛠
danzimbric #1258928 03/17/2018 1:14 AM
Not advisable to run different diameters (actual diameter) on the rear
1952 Chevrolet 3800 pickup
---All pictures---
danzimbric #1258941 03/17/2018 2:22 AM
Dually tires should be a matching set (all 4) with the same tread thickness and air pressure to prevent overheating which will cause tread separation and or catastrophic blowouts.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
danzimbric #1259124 03/18/2018 5:03 PM
I really appreciate everyone’s advice.
