8 members (carbking, 3B, msmall, Bill Hanlon, FrankenChevy, walter74, Stovebolt48, Shardean),
58
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | My quest is over, Eastern Surplus & Equipment has 20 inch 6 bolt stud centered military surplus rims in stock to fit my ‘56 C65.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Do you mean a 56 6500 series ?
| | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Yes, they just arrived yeasterday. Nice rim with tire that has 70% tread for $130/ea
Are there any restrictions running military tires on the highway? Do they meet DOT requirements?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Look on the sidewall of the tire. If DOT approved it will say so.
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Military tires with the cross bar type tread are meant for off-road use. They have a nasty habit of spinning a vehicle out if somebody spits on the street three blocks away. Make sure you have good liability insurance coverage before you go out in the rain. Jerry
| | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Jerry is correct, I have a full set of DOT approved military tires on a 4x4 dump truck. They are not good road tires. Off road, not that good either, on a 13,000 lb truck unloaded.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | I remember driving a Jeep with non-directional combat tires down I5 in the pouring rain. We didn't think about how bad the tires were for freeway use. I suppose that's why the vehicles had governors restricting us to a max of 55 mph!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Good to know, any potential problems running a mix of military and dot on the rear with dot tires on the front with both sides are equal on the rear (1 mil and 1 dot on each side)? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Mechanically no. Legally yes. Non DOT tires run on public roads can get you a hefty fine if caught.ðŸ›
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not advisable to run different diameters (actual diameter) on the rear | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Dually tires should be a matching set (all 4) with the same tread thickness and air pressure to prevent overheating which will cause tread separation and or catastrophic blowouts. Mike B  | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Thanks I really appreciate everyone’s advice. | | |
