2 members (Joe H, Naturalthud),
196
0
Mod | | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I am sure this has been answered somewhere but I can't find it. I have a six volt one wire alternator connected directly to the battery. My ammeter does not work now. From the diagram that I have in my shop manual, it looks like the power came out of the regulator and was split to go to both the ammeter ant the ignition switch. What is the proper way to connect the alternator to the system and get the ammeter to work. When I get this to happen, I will then install a volt meter so I can have both. A diagram and small words would be the best help. This is on my never ending 216 rebuild for my 52 One ton..
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 |
