| | | Forums66 Topics128,089 Posts1,056,428 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I've been searching for the last couple of hours about rebuild kits for the SM420. I know this has been discussed frequently before. I have read Novak's site many times and they seem to be the go to source. I found a place called Transparts Warehouse that produces a kit and it is available on eBay. With a one day eBay discount I can get a kit for about $88 USD with free shipping. (I'm ordering from Canada and our dollar isn't doing well right now!) I'm not sure if it comes with instructions but I do have the links to the GM slide show and shop manuals about rebuilding the SM420. I'm well aware of 'you get what you pay for', but has anyone purchased a non Novak rebuild kit? Are the instructions from Novak different than the GM instructions (in particular, the GM instructions say to use this GM tool or that GM tool. Do the Novak instructions overcome this with information as to use readily available tools? (Novak does state on their site that common shop tools can be used.) If anyone has purchased a non Novak kit, how was the quality? If quality could be the same, approximately $100 is a lot to pay for some instructions. Also, from what I can gather, synchros are no longer available in the Novak kits. Any insight into this would be greatly appreciated. Thanks.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The whole job is pretty straightforward using normal shop tools like it says. Don't be scared.
Ed
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I just got done rebuilding two SM420s and it was pretty straightforward. Bought the bearing kits on ebay for little over $100. One trans went in my 53 and I am selling the other. I have a lot of sm420 build pictures if you send me your email addy. Would recommend a press and a large bearing separator, and lock rings pliers. Also , there is a good GM SM420 repair guide that I could email you that offers step by step on disassembly and reassembly.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | I got all of my rebuild SM420 parts from these guys. http://www.americanpowertrainwarehouse.com/sm420-48-67-manual/I watched the GM slideshow numerous times. I have a friend with a press so that helped. I'm no transmission guy but I didn't have any issues.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Thats right Red, pretty straight forward. Important to make sure you have .012 clearance between the second gear thrustwasher and 2nd gear. Other than that make sure everything is nice and clean and replace all the bearings and lock rings and of course worn components. This is one of the stoutest trans I have ever seen in a light truck. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
