4 members (NJC, Otto Skorzeny, Steveoreno, 1955 1 Series), 92 guests, and 4 robots.
Topics128,192
Posts1,057,234
Members48,465
Any suggestion on how to primer and paint the inside of the bed pockets and the bed side rolled top?
Stick your gun in the opening and pull the trigger???
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
Not much use in pulling the trigger unless the metal is prepped first.
AD.. is the color on your truck dash the coorect color. if so can you send me the paint number
Thanks Dave
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
I first used Eastwood rust converter and followed the directions,then poured there black rust incapsulating paint in and with the help of a few friends moved the panels around to allow the paint to cover all sides, After that dried I then poured in black Rustoleom and repeated the process I did this for the inside of my doors as well. lay down some plastic for the spillage. It was not pretty but it will not rust. Por 15 would work as well but I found this to be less expensive. Good luck.
David Sr, From the DuPont 1953 Chevrolet Truck Color Bullentin No. 25 that color is Sheen Gray Metallic.
Duco Stock Order Number - 740
Duco Code - 202-81407
I took a sample from my truck to a paint supplier and they mixed to match the color.
Gee thanks for all the Ideas!
New bed, Ready for primer and paint.
