0 members (),
347
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | How do you lock a 1946 Chevy truck? I guess they were built in a trusting time, but I see no way of locking the doors! I notice a bolt head that twists on the upper part of the door when I open the door.
Does anyone have anyone have a work around? My truck is not original and I'm even considering electronic locks!
Dan Mascheck Wharton, TX | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | You can do the mod for electronic locks, but if you want to go original there was a door lock.
The key lock was on the passenger door and there was an inside lock on the drivers side.
You can find replacement parts through the suppliers. That bolt head had a plastic T that allowed you to twist the lock into place. | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Mine has a key on the driver side lock, but alas no key to use on it. I notice the bolt heads that twist on the door inside, but fail to see how they would lock the door. I need to call someone about the item you described! I wish there was a 46 around the area I could look at that had the locks so I could get a better idea!
Who do you use for parts?
Dan Mascheck Wharton, TX | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | On my 46 the key lock is on the passenger door just below where the handle goes into the mechanism. The mechanism is a very simple cam type lever that rolls into the opening mechanism and jams it from opening. Very simple mechanism. The passenger door opens locks from the inside only while the drivers side locks from the inside and outside using the key. Hope that helps. Bob T | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Mine is the same. I didn't notice the key below the handle on the passenger side. It does seem a bit odd. I just wonder where I can get a key made at? Where do you find one for an old 46? I also need the lock for the driver side.
I also think you mean the driver side door locks from the inside only. And the passenger side can be locked from the outside with the key. Where can you get the locking mechanism for the inside for the driver side door?
Dan | | | | | Joined: Apr 2015 Posts: 1 Moderated | | Moderated Joined: Apr 2015 Posts: 1 | My first time with this forum. I have a 46 pickup that has been made into a street rod with power windows. Question about door lock on passenger side. I have key that works and turns lock but it does not lock the door. Does the lock need to be turned to where the key goes into the lock top up or does it make any difference. I want to lock door. Thanks | | |
