1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
I just spent 2.5 hrs cleaning and painting my ('50 216) Intake/Exhaust Manifold that's in excellent shape to put on my fresh (235) with a '59 head.
When it came time to install the Intake Rings.......you guessed it, they didn't fit. Early 50's 216 manifold has smaller ports than Late 50's 235 head.
The Manifold on my (core) 235 is "toast", that's why I was wanting to use the 216 Manifold.
I read that you can put the (216) manifold on the (235) head without installing the Intake Rings. Kind of "Mickey Mouse" (but if it works....)
What would be the "Cons" to doing this? I not concerned about performance.
I did see an earlier Post here by "Big Tee" (post # 729906), a few years back he was doing this very same thing but (if I remember right)
I believe he was planning to ream out the Intake manifold to accept the larger Rings. I plan to PM him.
what do you think? Can I use my 216 without the Intake Rings?
Jim
H Online: Content
Short answer- - - -yes the manifold will bolt on without the rings. However, there's about a 99.9% chance you'll have a vacuum leak. There are stepped-down rings designed to make the manifold/head mismatch align properly. I think some of the resto-parts places sell them, and they aren't expensive. You can also make your own step-down rings by using pieces of exhaust pipe tubing and a little tinkering. The rings don't seal- - - -they just keep the manifold and head aligned so the gasket doesn't slip out of place.
I think that Larrowe & Sons sells those adapter rings, and Patrick's used to sell them.
If MotherTrucker stills sells them, you can count on him following through on the sale.
Photos below from MotherTrucker (from the HAMB, 2017)
on eBay - sold by ??
Thanks guys,
I just ordered them.
This forum is great, such a huge help.
Jim
