1 members (edgardo),
79
Mod | | | Forums66 Topics128,057 Posts1,055,808 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12576 06/01/2003 6:40 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Hi guys. I have a 68 chevy that has had some tranny problems. Engine is a 250. Originally it had a 3 on the tree, 4 side bolt side Muncie. Due to unavailabilty (and severe lack of funds at the time) I swapped it for a Muncie 4 spd. Now, I have to swap it to an automatic (bum knee). I've read the articles listed, but the seem to be geared (sorry, had to) for trucks older than mine. Q: What automatics will fit and work well? Thanks, Pal
35 + years of rollin' steel!
#12577 06/01/2003 7:01 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Hello Pal, Welcome to the Stovebolt I would go with a TH-350,,, a TH-400 or a TH-700R4 for the overdrive capability. I would not use O.D. around town or going over long hills especially when towing. Other than that. You will need to use a driveline for the same truck you have W/automatic. Should be fairly easy to find. The TH-400 will have a different output shaft so you will need the slip-yoke for the TH-400 and there are u-joints that will fit the yoke to the driveline if needed.
#12578 06/01/2003 11:12 PM | | Anonymous Unregistered | | Anonymous Unregistered | Pal, if you are going to go to all the work to put in a tranny - double check your rearend gears before you make your choice. If you have 3.90 or 4.10 or 4.11 gears go ahead and put in a 700R4 - expecially if you do any long distance driving without a load.
Sorry to hear about your knee - I would be bummin if I couldn't use a clutch. | | |
#12579 06/03/2003 12:24 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also go with the 200R4 behind the 250. It's not as strong as the 700R4, but more than adequate for the 250. I would advise against the TH400, it robs several horses. The TH350 would be a better choice for a 3 speed behind your engine.
Some people swear by the Powerglide, which was available in 68. I had experience with the back then, the only one I had success with was in a Nova behind a 194. It is another option.
Fred 52 3600 69 C-10
#12580 06/03/2003 2:04 AM | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | Hi, I don't know how much you want to lay out for the OD, but Chevy High Performance magasine has a good article (may 03) on making the th200-4r bullet-proof. It is said the ratios in the lower gears is closer compared to the 700r4. Not all mods would be needed for lower power daily drivers. Supposed to be an easy install(conversion) Good luck and let us know how things go.Tom
65 C10 292/700R4 long fleet...Gettin closer by the day.
#12581 06/03/2003 2:08 AM | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | Hi, I don't know how much you want to lay out for the OD, but Chevy High Performance magasine has a good article (may 03) on making the th200-4r bullet-proof. It is said the ratios in the lower gears is closer compared to the 700r4. Not all mods would be needed for lower power daily drivers. Supposed to be an easy install(conversion) Good luck and let us know how things go.Tom
#12582 06/03/2003 2:42 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Thanks for the info and the welcomes. And Ken, the knee isn't terrible, just gives me trouble if I get stuck in traffic jams (in Seattle area? Naw, we don't get those) Mama just gets tired of me limping...... Anyway, it'll probable be awhile till I make the conversion. I just blew all my spare cash on 250 LB from Ram in Spokane. I get to install it in a week. Thanks again all. Dave 30+ years of rollin steel!
#12583 06/03/2003 3:11 AM | | Anonymous Unregistered | | Anonymous Unregistered | Hey Pal - where abouts in Puyallup you at? I grew up in Black Diamond and remember "Doin the Puyallup" on several occations with my '49. | | |
#12584 06/03/2003 3:31 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | South Hill area. I own a couple of acres out here. Now if I just had a garage! :mad:
