0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 11 New Guy | | New Guy Joined: Nov 2017 Posts: 11 | My oil filter cannister gasket is cracked and brittle. Need a new one, but can't locate one to buy. Any ideas? 1962 235 engine. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tape it together as best as you can on a sheet of paper and take it to NAPA, if you have one. If not try any auto parts store or Tractor Supply. You may get lucky. Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2010 Posts: 2,332 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,332 | What brand of filter . A few years ago i was using krawlinator k55a if i remember right the number but please check.the filter came with the gasket. Rubber and a paper washer for under the nut .my truck is a 54 with a 235 .yours may be different ? | | | | | Joined: Sep 2010 Posts: 2,332 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,332 | Google k55a krawlinator filter and hit the images it will dhow a picture of the filter with the gaskets if your truck uses the same filter | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | A new filter typically comes with a new seal. You may have to cross reference numbers to find one that fits. Wix typically has one that will fit. | | | | | Joined: Jun 2009 Posts: 805 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 805 | Get a sheet of cork gasket material from your FLAPS and cut one out for yourself. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Go to your FLAPS or a TSC and look for a WIX 51100, 51006 or a Fram 1100. These are cartridge type oil filters of very similar size (they are basically interchangable). They include a rubber top seal. Take your old one and see if they match up. Good luck Dave | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Take the top of the canister with you when you go filter shopping. Check the gasket that's included with the filter element to be sure the gasket fits the lid. Some filters come with two different diameter gaskets to fit different canisters. Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | WIX 15039 fits AC canister, WIX 15017 fits Fram and Innerline canister filters. Your may be able to cross them to another manufacturer.
Ed
