| | | Forums66 Topics128,100 Posts1,056,514 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | I am looking to replace the front mounts on my 235 (rubber only, the brackets look okay) and all I can find are 8 cylinder kits. Classic Industries does sell a 8 piece bushing set that looks like mine as best as I can tell, but it also says it is for the V8. Can anyone tell me where I can find the proper bushings? Or is it a matter of taking them out and going by a hardware store to find something that matches?
Thanks, Lee
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Classic Parts has what you need: part number 79-011. Price is $59.95
Steve
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Lee, they are the same for the 6 and the 8. If all your metal parts are good, you can just change out the rubber bushings. There are two types. You will need four of each. They are available from Rockauto for about forty cents apiece. Anchor #2122 and # 2123.
The flat washers and fine thread castle nuts should be available any hardware store if you want to replace them. Clean up the studs and cupped washers, paint them flat black with a rattle can, install new rubber bushings, flat washers and castle nuts and your motor mounts will look brand new for under $10.00 !!!
Matt | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thanks Matt, that is what I needed to know.
