0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | 1948 Chevrolet 1/2 Ton Pick-up, I'm removing everything from the cab so I can strip and re-paint. Is there any particular way to remove the 2 windshield wiper arms from the body? Mine seems to have an electric motor with a long shaft that connects the 2 arms. I can't see how to remove each arm from that metal shaft? Appreciate any helpful tips. | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Don't have a 48, so reluctant to give you advise. You will get a faster reply if you post it in the General forum.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | There may be a small metal tab underneath you have to push while prying up on the arms. If not, then they just pry off using a crows foot bar or a couple of large screw drivers.ðŸ›
| | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Thanks Justhorsenround, it sorta looks that way, like a pin from the wiper arm is going thru the cab and into a flat metal tab that is the shaft connected to the wiper motor, I'll put some wd40 and try to push/pry it out the whole thing out. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Are we talking the same part? To me, and most others, the wiper arm is the shiny arm that the rubber blade attaches to. It sounds like your talking the shaft that connects the actuating arms through the body to the wiper arms. If so, someone else will have to chime in as I have never removed the shafts before.ðŸ›
| | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | yeah, that's what I'm asking about, I need to completely remove the actuating arm from the body. It doesn't appear to have any nut or bolt on the inside, just a Pin thru the actuating arms. I haven't done anything with it yet, too cold outside. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Martin already said how to pry up, rock, wiggle the wiper arm while releasing the clip under the "chrome" arm (Wiper Arms). The under dash arms are called Transmission Arms. Then take off the nut and bezel where the wiper arm splined shaft comes thru the cowl.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Got 'em!!! Whew, glad I waited and read the collective of all the tips, they were very helpful. There are 5 or 6 steps here to observe:
1) Position arms at 12'oclock 2) There is a small, hardly noticeable latch spring on the inside of the chrome arm cover at the spindle, it is now in the 12'oclock position on each arm 3) push upward on the latch spring and this will facilitate sliding off the chrome arm cover at the spindle 4) with chrome arms removed, loosen the chrome locking nut on the top of each chrome bezel that shrouds the spindle 5) with the chrome locking nut removed, the chrome bezels can be pulled off, away from the spindles and off the cab 6) the spindles can now be gently pushed down, tucked into the cab to facilitate sanding, stripping, painting of the exterior.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good work Bobby! You owe Martin a coke.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | There ya go. Task accomplished!ðŸ›
