0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#1257396 03/04/2018 4:35 PM
I am looking to replace the front mounts on my 235 (rubber only, the brackets look okay) and all I can find are 8 cylinder kits. Classic Industries does sell a 8 piece bushing set that looks like mine as best as I can tell, but it also says it is for the V8. Can anyone tell me where I can find the proper bushings? Or is it a matter of taking them out and going by a hardware store to find something that matches?
Thanks, Lee
1956 Chevy 3200, 235 w/3 speed
Classic Parts has what you need: part number 79-011. Price is $59.95
Steve
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Lee, they are the same for the 6 and the 8. If all your metal parts are good, you can just change out the rubber bushings. There are two types. You will need four of each. They are available from Rockauto for about forty cents apiece. Anchor #2122 and # 2123.
The flat washers and fine thread castle nuts should be available any hardware store if you want to replace them. Clean up the studs and cupped washers, paint them flat black with a rattle can, install new rubber bushings, flat washers and castle nuts and your motor mounts will look brand new for under $10.00 !!!
Matt
Thanks Matt, that is what I needed to know.
