1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#1257211 03/03/2018 2:56 AM
I was talking to a local mechanic and he suggested I might want to keep my SM420 with the original 235 and Camaro 2:56 rear end instead of using the T-5 I built up for it. Any thoughts? I was planning to change the 2.56 to 3.73 rear end with the T-5.
Comments either way.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
Well, my question is, what did you do to build up your T-5?
1949 3600
Don't sweat the petty things, and don't pet the sweaty things.
Never play leap-frog with a Unicorn.
2 Wrongs don't make a right, but 3 lefts do.
Of all the Henges, Stone is my favorite.
If at first you don't succeed, skydiving is not for you.
Here's a word I just made up.....Plagiarism.
It has been rebuilt and the shaft changed to a Jeep shaft to mate up with the clutch. It is currently installed in the truck and came out of an S-10. I guess my main reason for considering changing back is I have never rebuilt a rear end and am not sure where to start. I'm sure I could find something on the internet, but this conversation just started so I haven't progressed that far yet. I have plenty of time since the truck is still off the frame anyway, just the frame, engine and tranny there.
Riding in the Passing Lane
I would use the t-5 even if you keep the 2.56 rear end. unless you are going to do some heavy hauling. You wouldn't have to use 5th gear. You will have smoother shifts with closer ratio's.
George
1972 Chevy c10 Cheyenne Super
To figure out what gears you might like do some math, input your numbers in a gear calculator and see what makes sense for your driving style/speed.
http://www.onlineconversion.com/bigger_tires.htm
I’ve taken very long trips with a 235 and mine seemed very comfortable at about 2,450 RPM, all day long, much faster and fuel mileage suffered.
1952 Chevrolet 3800 pickup
---All pictures---
Sounds like I should leave the rear alone, keep the T-5 and see how she runs when I get it on the road. If I don't like it, go to different rear end gears then.
Maybe I missed it somewhere, but what size truck is the T-5 going in?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It is in a '54 3600.
Will the T-5 be the weak link in the drivetrain? I think of T-5's as being car transmissions...BUT I have never owned one so maybe I'm wrong in my thinking.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Insomniac
Insomniac
Yes, I believe that is a good plan. Using a Camaro rear end, there are lots of options if you want to change gears after road testing.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Mike B,
I plan to use it as a daily driver, not much hauling. I have two other trucks to haul anything of size.
