7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC),
60
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For the past ten years and 40K miles, my 1951 216 has always registered a somewhat lower than normal oil pressure reading. Over the years I have replaced the main bearings, the oil pump and the oil distributor valve. My eventual conclusion was that the cam bearings must be really worn. Well I just put the motor back in my truck after rebuilding it with .040 pistons, etc. The oil pressure readings haven't changed. So I hooked up a gauge from my spare 1938 cluster and the pressure gauge in my truck is reading quite a bit lower than the spare gauge. So I have a new gauge for my truck ordered and on the way! | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I suspect the oil pressure gauge in my 49 is off too. It's slow to register and doesn't show any deviation between idle and at speed. I know I'm getting good oil pressure to the valve train so I dunno. I should put my very accurate oil pressure tester on it and see but I haven't gotten "round toit" yet LOL.
It's amazing these 60+ yr old engines and their components are still tick'n and still taking a lick'n .....
Dave | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | And they don't have computers in them that like to complain about everything turn on little scary lights! | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | LOL! That's what I love about these trucks. No computer to foul up the works. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I have an extra set of gauges just in case one of them suddenly retires.....without my blessing. What if my spare oil pressure gauge showed less than the current one. So, hopefully the current one will stay strong for me.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
