3 members (MickeyP, TexasJim50, 3B), 56 guests, and 7 robots.
Topics128,013
Posts1,055,322
Members48,419
#1257096 03/02/2018 3:01 PM
For the past ten years and 40K miles, my 1951 216 has always registered a somewhat lower than normal oil pressure reading. Over the years I have replaced the main bearings, the oil pump and the oil distributor valve. My eventual conclusion was that the cam bearings must be really worn. Well I just put the motor back in my truck after rebuilding it with .040 pistons, etc. The oil pressure readings haven't changed. So I hooked up a gauge from my spare 1938 cluster and the pressure gauge in my truck is reading quite a bit lower than the spare gauge. So I have a new gauge for my truck ordered and on the way!
1951 1 Ton Completed
V
V Offline
I suspect the oil pressure gauge in my 49 is off too. It's slow to register and doesn't show any deviation between idle and at speed. I know I'm getting good oil pressure to the valve train so I dunno.
I should put my very accurate oil pressure tester on it and see but I haven't gotten "round toit" yet LOL.
It's amazing these 60+ yr old engines and their components are still tick'n and still taking a lick'n .....
Dave
And they don't have computers in them that like to complain about everything turn on little scary lights!
LOL! That's what I love about these trucks. No computer to foul up the works.
I have an extra set of gauges just in case one of them suddenly retires.....without my blessing. What if my spare oil pressure gauge showed less than the current one. So, hopefully the current one will stay strong for me.
Craig
