6 members (TUTS 59, Gdads51, kades51, MickeyP, Jon G, KCMongo), 76 guests, and 2 robots.
Topics128,051
Posts1,055,705
#1256954 03/01/2018 4:26 PM
Need some info on 59 1/2 ton King pin bearings ?
I have looked in the manual but I"m confused , which side the copper goes on ? ( I know on the bottom of spindle ) would it be copper to copper ,(pancake together ) with dust shields around , or ??? OR have I got it all mixed up ? I did see the Tech write up , Thanks for your help !
P S I wish I could post pics , The easy way ? no pics for me
59 chevy apache fleetside
2007 dodge diesel
84 toyota 4 runner, v8,propane power
old55guy #1256988 03/01/2018 7:33 PM
So after doing more research , I hope I have the right answer ? First it"s not copper its brass ,
Assemble thrust washers. Place one small and one large diameter cup washer on work bench with
open end up. Place one thrust washer in each cup washer with brass side facing up. Apply a coat of
bearing grease to each brass thrust surface. Invert large cup washer (with thrust washer) and place on
top of small cup washer (with thrust washer) Might help the next guy
2007 dodge diesel
