2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Need some info on 59 1/2 ton King pin bearings ? I have looked in the manual but I"m confused , which side the copper goes on ? ( I know on the bottom of spindle ) would it be copper to copper ,(pancake together ) with dust shields around , or ??? OR have I got it all mixed up ? I did see the Tech write up , Thanks for your help ! P S I wish I could post pics , The easy way ? no pics for me
59 chevy apache fleetside
2007 dodge diesel 84 toyota 4 runner, v8,propane power
| | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | So after doing more research , I hope I have the right answer ? First it"s not copper its brass ,
Assemble thrust washers. Place one small and one large diameter cup washer on work bench with open end up. Place one thrust washer in each cup washer with brass side facing up. Apply a coat of bearing grease to each brass thrust surface. Invert large cup washer (with thrust washer) and place on top of small cup washer (with thrust washer) Might help the next guy
