6 members (Gdads51, Otto Skorzeny, TUTS 59, amtrakjoe, fonz8261, mk72), 78 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#1256894 03/01/2018 3:11 AM
Going SBC with 350 TH automatic In the 54 3100. I will also put in a new after-market tilt steering column. I need to decide whether to order a steering column with shifter, or go with the Lokar floor shift. What's your experience? I am also wondering if the original brake pedal arm will interfere with column shift linkage.
If you are staying with a bench seat you may want the column shifter to allow for 3 people. If you are converting to buckets I would use the Lokar floor shift. Excellent product that installs and works right. drive
