6 members (Wally / Montana, gswbbc, TexasJim50, tclederman, TIM ZINDLER, 1 invisible), 170 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#1256894 03/01/2018 3:11 AM
Going SBC with 350 TH automatic In the 54 3100. I will also put in a new after-market tilt steering column. I need to decide whether to order a steering column with shifter, or go with the Lokar floor shift. What's your experience? I am also wondering if the original brake pedal arm will interfere with column shift linkage.
If you are staying with a bench seat you may want the column shifter to allow for 3 people. If you are converting to buckets I would use the Lokar floor shift. Excellent product that installs and works right. drive
