1 members (Forty9), 64 guests, and 2 robots.
Topics128,043
Posts1,055,610
#12561 09/03/2004 2:24 AM
Hi bolters! Just got my vacuum wiper motor back from Ficken wiper service who did a total rebuild. Motor works like a dream! Thought it was going to wipe a hole in the window! I highly recommend the "Wiperman"!
KT
1949 3/4 ton Cheby
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#12562 09/04/2004 3:53 AM
Junior Member
Junior Member
Good to hear...I sent mine off to them 3 days ago. 55.1 Chevy 3100
Bob
#12563 09/04/2004 8:12 PM
kthomas, curious what the cost was for the wiper motor rebuild? Also when I picked up my 53 Suburban, I think the engine had been changed to a 235. There is no vacuum anywhere that I can see, including for the vacuum advance or wipers. Anyone know where to pull vacuum from :confused: ?
#12564 09/04/2004 9:11 PM
Krissy 1, The rebuild cost $59.00 + $5.00 S&H. Not bad for a motor that works! On your vacuun question, there should be a brass fitting on the intake manifold just below the carberator that the vacuum line fits on. Do you have that?
KT
1949 3/4 ton Cheby
#12565 09/05/2004 1:20 AM
Sorry for the mis-spelling. I meant Krissly 1 !
#12566 09/05/2004 1:37 AM
There is a 5/8" fitting, but it has a hose connected and runs up and into the top of the valve cover.
#12567 09/05/2004 8:43 AM
well that hose would go to run your wiper motor someone used it to suck the crank case blowby
#12568 09/05/2004 4:28 PM
Is there another fitting? My fitting is just a 90 deg elbo. Should there be a fitting with connections for my vacuum advance, crankcase and my wipers? I don't know how to post a photo on the forum, but could email one if that would help someone help me. Maybe someone could post a photo of there intake manifold at the base of the carb. showing the fitting with vacuum attached?
#12569 09/05/2004 4:47 PM
ODSS President
ODSS President
Don't forget, he gives a LIFETIME WARRANTY! I recently had a problem with mine and he sent the part I needed free of charge! Class act.
~ Cosmo
1949 Chevy Half Ton
#12570 09/05/2004 5:14 PM
Here is a link to my photo album, which includes photo's of my Suburban. The first photo is where my problem is. Any help is appreciated.
http://community.webshots.com/scripts/editPhotos.fcgi?action=viewall&albumID=183821322
#12571 09/05/2004 7:37 PM
Hey kthomas,
Just wondering why you decided to have your motor rebuilt? Was it not working at all? What'd you do to determine you needed a rebuild?
On my Pontiac when I turn the wipers on, they go up halfway and stop. They don't go down until I turn the switch off. I was thinking things just might be gummed up here and there. Lord knows the cable going to switch on motor was gummed up!
David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#12572 09/05/2004 11:28 PM
Hi David (mugsy), no the motor didn't want to work at all. I tore it apart and inspected it, but it wasn't all gummed up like they get. It looked good, but was dry. I put some light lube in it and put it back togather. I checked the vacuum on the truck, and it had plenty. I checked the torque on the manifold bolts and it was good, but the motor just wouldn't work the wipers. If yours is just going halfway up, and stopping, and you have to turn the knob to make then go back to rest position, then I feel that you should consider having yours rebuilt also. After so many years, these old motors get tired. It was the best $64.00 I ever spent. My wipers work great now, and the motor has a 3 year warranty. Not too long ago I sent the motor from my wife's 50 Chevy truck to Jim Carter for to exchange for a rebuilt one. It cost me $52.00. However, it still don't work very good. They say that they clean them up, lube them, and replace some parts. Ficken wiper repair replaces the paddle inside. I think that makes a big difference. Since mine works so good, I am going to send her motor to Ficken, wink that I got from Jim Carter and have them rebuild it.
#12573 09/07/2004 5:02 AM
say there , could you post the address for wicken wiper co. i could use it and i am sure others could too.
cliff
39 chevy suburban w/250-6cyl "Valve in head means ahead in value"
#12574 09/07/2004 11:37 AM
cliff,
www.wiperman.com is the URL for Ficken Wiper Service.
Tim
#12575 09/08/2004 1:25 AM
smile Thanks tclederman for posting Robs e-mail address!
KT
49 3/4 ton Chevy
