8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | What is the method of removal for the windshield for a '66? I am new at this and am in need of some advice. I sure don't want to break it. Thanks a lot for any help. Michigan boy.
GS
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're going to re-use the glass, take a sharp utility knife and cut the rubber outside until someone inside can push the glass out - just go slow and cut enuff that it doesn't take much pressure to get it loose - not hard to do, just tedious
Bill | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | The second and preferred method I use is to cut the gasket around the inside of the pinchweld. The utility knife can break the glass on the outside if not careful. | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | thaks for the tips. I'm dipping the cab so the windshield has to go. I really wanted to just dip the bottom 18" or so but nobody will do that so I gotta get everything out. Just more time.
GS
