6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#125654 04/18/2007 2:33 PM
What is the method of removal for the windshield for a '66? I am new at this and am in need of some advice. I sure don't want to break it.
Thanks a lot for any help.
Michigan boy.
GS
#125655 04/18/2007 3:14 PM
if you're going to re-use the glass, take a sharp utility knife and cut the rubber outside until someone inside can push the glass out - just go slow and cut enuff that it doesn't take much pressure to get it loose - not hard to do, just tedious
#125656 04/18/2007 6:37 PM
The second and preferred method I use is to cut the gasket around the inside of the pinchweld. The utility knife can break the glass on the outside if not careful.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#125657 04/18/2007 10:58 PM
thaks for the tips. I'm dipping the cab so the windshield has to go. I really wanted to just dip the bottom 18" or so but nobody will do that so I gotta get everything out. Just more time.
GS
