10 members (Jay R, Gdads51, baldeagle, greenie-reddy, Wayne67vert, 68ironhead, 3B, JW51, walter74, 1 invisible),
51
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've got some body parts that have been primed but I'm not sure what was used. Hopefully, they used epoxy. Any idea how I could figure that out? The painter is no longer around to ask.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dennis,
I do not know. I have never done this.
However, rubbing with Xylene is used to see if a pool is epoxy painted/coated.
Wait to hear from someone who knows. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I read some time ago ,to put laquer thinner on a rag and wipe it in a small section . If it's a true epoxy primer , it will not come off onto the rag. I tried this on my own epoxy primed part , and it did not show on my rag. Do a google search on the subject and see what you find.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | A solvent test, as you've done with the rag, is used on any coating to test it's solvent resistance. It doesn't prove or disprove that the coating you have is an epoxy because urethane primer is also resistant to solvent. However, you now know that the coating is not lacquer as it is not solvent resistant and would transfer to your rag.. | | |
