1 members (1 invisible), 103 guests, and 0 robots.
Topics128,117
Posts1,056,298
Members48,439
#1256331 02/25/2018 2:04 AM
I purchased a Chevy261 which had been removed from vehicle before purchase. It was locked up at the time. I have since torn it down, cleaned it up and installed new rings. Getting ready to try to fire it up and noticed that the right hand bolt on the fuel pump (double action type) has a special bolt that includes a tube that runs all the way through to the crankcase. I can't seem to figure out if this is for some type of oil line return or something else. Anyone ever see this before. My 261 is set up for running without an oil filter - I've checked that the dow pin is in correct position to bypass filter and still lubricate the engine.
Any idea what this special bolt/tube is on my fuel pump?
Vacuum assist for your wipers?🛠
Clark6400,
Can you you post/attach a photo or two?
found a couple other threads that suggest it may have been connected in some way to the vacuum pump on the fuel filter - but no one seems to know why. I think I'll leave it and just put a plug over the top of it to keep it clean and open in case I ever figure out the purpose for it.
I have a pic of it but having trouble figuring out how to post pics. I'll see if I can figure it out and post pic later.
That location is not where the a vacuum pump fitting would attach on a dual action fuel pump (that I have seen).
I have several dual-action fuel pumps (but they are for the 47-55st truck - maybe your pump was for/from some other type of vehicle)?
Here is a WAG: a line to a home-made PCV set-up?
Moderator
Moderator
2 Offline
This is just a guess.
Could it be a weep hole for the fuel side?
It appears to be between the fuel diaphragm and the vacuum diaphragm.
Or a vent between the two diaphragms to prevent pressure build up?
Just a guess.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
whats the numbers on the metal tag that is attached to the fuel pump ?
Tim
1951 3100 Chevrolet
Is there a possibility that the engine is from a former military application? I had a M-151 Jeep once that had what appeared to be a vacuum boosted fuel pump which was actually a small air pump. Its purpose was to keep a slight amount of positive pressure in the crankcase when a snorkel and a high exhaust pipe was attached for deep water fording- - - -keeping water out of the engine while it was totally submerged. Pressure lines also went from that pump to the distributor and the alternator. As long as the driver could keep his head above water, moderate-depth flooded roads could be negotiated.
