2 members (Tinker5, klhansen),
121
Mod | | | Forums66 Topics128,193 Posts1,057,256 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I was wondering if there is any filter kits made for a 235 that uses a modern spin on filter,the last one I bought was around 12 dollars and I can get good spin on filters for less then 5 dollars. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | There are adapters for spin-on filters that can be plumbed to a stovebolt engine, but they would have to be modified with a restrictor orfice with about a 1/16" hole in it to control the rate of flow. Using a regular full flow filter in place of the canister-type bypass filter would starve the engine for lubrication and engine life would be measured in minutes. The filter media would also be way too free-flowing to do much good compared to the right filter. There are spin-on hydraulic oil filters with about the correct micron rating to replace the bypass filter, but the price would probably be about the same as the canister filter element. Jerry
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Fram PB50. It has the small 1/16" restriction hole built into the filter. | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Deve's site has a lot of information on installing a spin on filter with an adapter Click here
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Similar idea for GMC six.
Ed
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Jeff, an alternative that you might want explore is a Frantz bypass filter. The replacement filter is very inexpensive...a roll of single ply toilet paper! http://www.frantzfilters.com/The newer, modern style advertised on the website is a bit pricey. The older model called the Sky that was made by John Frantz starting back in the 50's is usually easy to find on eBay with prices ranging anywhere from about $25 for a used one to $100 for a NOS one. John Frantz sold the rights to the older models to a guy named Ed who is a great guy to deal with and carries all of the parts such as gaskets for the old Sky model. He also sells a newer model similar to the Sky called the Refiner. Here is his website-- http://www.toiletpaperoilfilter.com/thetoiletpaperoilfiltercompany.htmlThe Frantz bracket will mount to the intake manifold just like the AC or Fram bypass canisters that we are accustomed do seeing. It is as easy to install as an AC or Fram bypass canister. You can use hard lines or soft lines if it is mounted to the manifold. Skeptics might think the idea is nuts. Hotrod Lincoln is the one who got me to think about using a Frantz a couple years ago when I was working on a project to install a spin-on canister filter on a full flow 261 combined with a bypass filter. He recommended the Frantz instead of a typical bypass canister. If you want to do some research, do a Google search and you'll find plenty of information. Matt | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Someone with a little machining ability can adapt a regular AC or Fram bypass filter canister to use a toilet paper roll. All it takes is a couple of pieces of 3/8" or 1/2" aluminum plate and a few O rings. Jerry
