Hello all, can I install my 46 half ton inner fenders so I can route the wiring etc and install a the main fenders later when they arrive from the painter?
Thanks Harold so much , great photo , your truck looks nice .What did you use for the rivets along the top that hold the inner and outer fenders together? I need all the help I can get. I'm also trying to figure out how the edge of the lower splash panel fits ,under or over the other sheet metal,thanks again, Jim Brown
I will be glad to answer questions you may have. I have done extensive research on this truck and will be happy to help.
I did not build mine to do "concourse" judging although it is as close to mfg. delivery as I could get. I used Philips head bolts (see photo) instead of rivets. If for any reason you have to pull a fender, just remove the bolts! I apologize the inner fender photo is so dark but you can see the bolts.
