3 members (1955 1 Series, WarEagle1, BC59), 127 guests, and 2 robots.
Topics128,169
Posts1,057,043
Members48,458
#1255877 02/21/2018 7:38 PM
Hello all, can I install my 46 half ton inner fenders so I can route the wiring etc and install a the main fenders later when they arrive from the painter?
Jcb3 #1255943 02/22/2018 4:43 AM
Yes, you can. That is how I did my truck. Be sure you have a helper to hold the big fenders while starting the bolts.
See photo.
Harold
Harold
Thanks Harold so much , great photo , your truck looks nice .What did you use for the rivets along the top that hold the inner and outer fenders together? I need all the help I can get. I'm also trying to figure out how the edge of the lower splash panel fits ,under or over the other sheet metal,thanks again, Jim Brown
Jcb3 #1256021 02/22/2018 7:13 PM
Jim,
Glad the photo helped.
I will be glad to answer questions you may have. I have done extensive research on this truck and will be happy to help.
I did not build mine to do "concourse" judging although it is as close to mfg. delivery as I could get.
I used Philips head bolts (see photo) instead of rivets. If for any reason you have to pull a fender, just remove the bolts!
I apologize the inner fender photo is so dark but you can see the bolts.
You can contact me on [email protected]
Haroild
Harold
