| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | I am finishing the sanding/sandblasting of my frame and am planning for paint. I want the rear end to be the same color as the frame. Do I need to use a high temp paint for this or can I just use what I am using on the frame itself?
Thanks for any advice. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just use the same as the frame. The rearend doesn't get hot enough, even with highway driving, to make it an issue with the paint.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks for the feedback Bill!
As usual, I appreciate your advice! You are always very helpful.
Ross | | |
