| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | My 47 Loadmaster 2 Ton has a leak in the PTO. The place I'm working with to try to get some seals are asking for the transmission model. After scraping 70 years of gunk off, I've found several numbers, but having trouble getting many online hits. Right by the shifter, on top of trans I have a " F 137". Also on the top of the transmission but on the driver side of the shifter I have a "590511" and a bowtie 10. On the side of the transmission also on the driver side, there are some characters but they are really hard to make out. Even after cleaning with solvent and a wire brush I'm still not sure. Something like "F1A70" with a big 3 below it. I'm pretty confident in the F, 1 and the 0. The A and 7 could be a 4 and who knows. The large 3 below those numbers is easy to make out. I know this is a long shot. Any ideas?
Oh yeah, the PTO is a Muncie with P64 stamped on a tag. I would think that would be enough for them, but they want the transmission model as well. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | If it is a loadmaster, you should have a SM420. As for your PTO seals, most likely there will be little known about the particular model. Seals can be sourced by determining the type of seal lip needed, the outside diameter of the shafts and inside diameter of the housing. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, in Canada the SM420 began in the 1948 model year, the sliding gear transmission was used into the first year of the new body design. Does your transmission have the reverse lockout rod coming up the side of the shifter? | | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Thanks for the feedback. Yes. I have the reverse lock on the side of the shifter. H pattern 4 speed. | | |
