1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12558 01/14/2002 1:15 AM | Joined: Jan 2002 Posts: 6 Member | | Member Joined: Jan 2002 Posts: 6 | I was wondering what gas tank should be put between the frame of a 68 pickup, 2WD? What kind of vehicle would it be out of? | | |
#12559 01/14/2002 3:39 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I installed one of those Aftermarket Polyurathane "Spelling" Blazer tanks in a 1967 Fleetside P.u. a month ago. It wasn't a bolt in like advertised. I had to still remove the factory bracket behind the rearend to get it to fit but the factory rivets holding the bracket came out easy after grinding off the heads. After that job it was easy. I had to run a new fuel line,extend the sender wire as well as attach a ground wire from the frame to the sender housing.
Joe
#12560 01/14/2002 1:00 PM | Joined: Dec 2001 Posts: 6 Member | | Member Joined: Dec 2001 Posts: 6 |
BATTERED WOMEN ? ! ! ? ? NO THANX , I like mine plain.
