3 members (Steelonsteel, Otto Skorzeny, 1 invisible), 60 guests, and 2 robots.
Topics128,054
Posts1,055,780
#1255703 02/20/2018 3:51 PM
My 47 Loadmaster 2 Ton has a leak in the PTO. The place I'm working with to try to get some seals are asking for the transmission model. After scraping 70 years of gunk off, I've found several numbers, but having trouble getting many online hits. Right by the shifter, on top of trans I have a " F 137". Also on the top of the transmission but on the driver side of the shifter I have a "590511" and a bowtie 10. On the side of the transmission also on the driver side, there are some characters but they are really hard to make out. Even after cleaning with solvent and a wire brush I'm still not sure. Something like "F1A70" with a big 3 below it. I'm pretty confident in the F, 1 and the 0. The A and 7 could be a 4 and who knows. The large 3 below those numbers is easy to make out. I know this is a long shot. Any ideas?
Oh yeah, the PTO is a Muncie with P64 stamped on a tag. I would think that would be enough for them, but they want the transmission model as well.
ljblue #1255710 02/20/2018 5:02 PM
If it is a loadmaster, you should have a SM420. As for your PTO seals, most likely there will be little known about the particular model. Seals can be sourced by determining the type of seal lip needed, the outside diameter of the shafts and inside diameter of the housing.
Lots more pictures
ljblue #1255716 02/20/2018 5:25 PM
Big Bolt Forum Moderator
this link may help you verify you have an SM420.
http://www.novak-adapt.com/knowledge/transmissions/manual/sm420
Mike
ljblue #1255841 02/21/2018 3:40 PM
3B Offline
Hy Guys, in Canada the SM420 began in the 1948 model year, the sliding gear transmission was used into the first year of the new body design. Does your transmission have the reverse lockout rod coming up the side of the shifter?
ljblue #1255852 02/21/2018 4:57 PM
Thanks for the feedback. Yes. I have the reverse lock on the side of the shifter. H pattern 4 speed.
