Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (jmoore, Otto Skorzeny, DoubleB, Lightholder's Dad), 328 guests, and 3 robots.
Topics128,275
Posts1,058,439
Members48,490
#1255603 02/19/2018 11:43 PM
Does anyone know of a product that removes MINOR scratches on vehicle glass? I thought I read about it but don't know where or if I imagined it .
Thanks,i will try it.
Only $69.99.
I guess it would make sense for a wrap around windshield on a Task Force. AD flat glass, not so much.
Most, if not all, Auto Glass shops can/do buff out scratches.🛠
Ex Hall Monitor
Ex Hall Monitor
You might PM jockbolter. He's a glass pro in Scotland. He can likely give you some pointers.
Pick up a small tub of cerium oxide at a glass shop. Most glass shops will sell you a small amount. Make a paste and polish away.
1970 VW Beetle
I have green tinted windshield glass (2 piece) in my expansive "inventory" with some wiper scratches in them that you can feel with your fingernail. I called a glass shop and they said that if that is the case, then they won't do it. I would like to give it a go myself just because.
Big Bolt Forum Moderator
You can also search Ebay for glass polishing powder
Mike
Most glass shops won't touch glass with scratches you can catch you finger nail in. They are too worried about distortion and possible shattering from too much heat. If you take it slow and keep the glass cool you should be able to get most of the scratches out. Might get a kittle distortion. If the scratches are in your direct line of sight, I would replace the windshield.
1970 VW Beetle
I suspect polishing glass would be the same as polishing paint: start with 2000-grit sandpaper, then progressively finer grits of rubbing compound, and finally polishing and finishing compounds. If the glass is already scratched, what do you have to lose?
Greatly diminishing supply of elbow grease, in my broken down condition. smile
