8 members (Southerntruck, Oswald, Millenimech, Otto Skorzeny, 3B, Wrenchman, Shade Baby, 1 invisible),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 8 New Guy | | New Guy Joined: Sep 2013 Posts: 8 | Greetings, I would love to do a little research before making a purchase but unsure where to start. I am interested in adding overdrive to my 66 chevy in-line 6. A quick search on CL found me a couple possible options. What should I be looking for to be certain one of these OD tranny options will work with my stock set-up? Thanks for any input!
WolfeCustom
Built this Chevy on Rock'n'Roll
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Do you know what transmission you have now? Is it a four bolt side cover ,or a seven bolt side cover? You want to get the same one that you have, that way will be a simple take one out, put the other in.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check out info online re. the T-5 BorgWarner, have one in my 46 behind a 261 and it's great. | | | | | Joined: Sep 2013 Posts: 8 New Guy | | New Guy Joined: Sep 2013 Posts: 8 | I know it's the stock 3 speed transmission, for a 250, I will crawl under it to look closer next chance I get. Thanks Tommy
WolfeCustom
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Unless it has been changed, the stock transmission would be a short tail shaft SM318. It has the 4 bolt side cover and a non syncro first gear. 66 was the first year for a full syncro Saganaw overdrive transmission to be offered for that truck. They are rather scarce and priced accordingly. The earlier factory overdrive, 55-65 is a SM319 is more readily available. It would also match the shift arms for your truck. Any overdrive change will require a driveshaft modification as they are longer than the stock transmission. There are electrical components and a pull cable required for each of these units to operate. Fred
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | To function as designed, a BW overdrive trans needs a cable-operated lock out installed, a kick down switch on the throttle linkage, a relay, and some wiring. The OEM relays and kick down are a little scarce, but the function can be duplicated with a Bosch-style relay and a micro switch with a little tinkering to fabricate a mounting bracket for the switch. Don't get persuaded to try to substitute a toggle switch for the right wiring- - - -it's very simple to make it work right. The wiring setup would be the same for either the Saginaw of the Muncie transmissions. If you have a choice, try to get a Saginaw. That synchronized 1st. gear is very handy, even if you have to modify the shift linkage a little to use it. I can provide a wiring diagram for the Bosch relay and micro switch if you find a transmission to buy. Jerry
| | | | | Joined: Sep 2013 Posts: 8 New Guy | | New Guy Joined: Sep 2013 Posts: 8 | Thanks for the input guys, this really helps.
WolfeCustom
| | | | | Joined: Sep 2013 Posts: 8 New Guy | | New Guy Joined: Sep 2013 Posts: 8 | I have read your (Fred and Jerry's) replies several times. I'll know more about what I'm working with when I finally meet the seller. Another commodity that is scarce right now is bread! I hope I can find you again when that time comes. Truck on.
WolfeCustom
| | | | | Joined: Oct 2017 Posts: 66 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 66 | If you have a 66 it will not have a muncie . It will be a saginaw. So you want a 7 bolt side cover 3 speed. These are fairly common. And interchange with the big gm cars. | | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | Got one in my current truck, a '65 3/4 ton. You will want 4.57 gears because the first gear of the 3-speed is too high. Not sure how it would work with 4.10 gears for taking off, but in overdrive it is a 30% drop in rpm's. It turns those 4.57's into 3.19's in overdrive. So the rear-end gearing is also something to be aware of.
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: Oct 2017 Posts: 66 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 66 | Loweboy. There are 4 different first gear ratios if you have the Saginaw swapped in. Could not get a factory 3/4 ton with the OD. You would want the 3.50 first. You may have the 2.54 or 2.84. | | |
