4 members (JW51, Mike Burns, MRMEROTH11, KEVINSKI), 121 guests, and 2 robots.
Topics128,133
Posts1,056,395
Members48,441
I've got some body parts that have been primed but I'm not sure what was used. Hopefully, they used epoxy. Any idea how I could figure that out? The painter is no longer around to ask.
Dennis
40 Chevy 1/2 ton
Dennis,
I do not know.
I have never done this.
However, rubbing with Xylene is used to see if a pool is epoxy painted/coated.
Wait to hear from someone who knows.
I read some time ago ,to put laquer thinner on a rag and wipe it in a small section . If it's a true epoxy primer , it will not come off onto the rag.
I tried this on my own epoxy primed part , and it did not show on my rag.
Do a google search on the subject and see what you find.
Tim
1951 3100 Chevrolet
A solvent test, as you've done with the rag, is used on any coating to test it's solvent resistance. It doesn't prove or disprove that the coating you have is an epoxy because urethane primer is also resistant to solvent. However, you now know that the coating is not lacquer as it is not solvent resistant and would transfer to your rag..
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
