4 members (Steelonsteel, Rich'sToys, Brian Moore, klhansen), 81 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#1255248 02/16/2018 9:46 PM
Question guys...
I have a brake drum on the rear of my 49 3800 that is stuck. I had it off about 8 years ago but now it is stuck tight. I have heard that they are nearly impossible to find replacements, so I don't want to pry and bang on it too hard. Any advice on getting it freed?
Back off the shoe adjusters, make sure the emergency brake cables aren't pulled tight, tap around the drum with a dead blow or rubber hammer and see if that helps. Probably just some rust making your job difficult. You can always put a big puller on the drum and carefully pull it after loosening the shoe adjustment.
You can also pull the axle shaft and remove the whole hub/drum assembly. It's easier to deal with a stuck drum on the workbench than it is to fight with it on the vehicle. Once it's on the bench (or the floor), support the drum on a couple of pieces of 2X4 and smack the center of the hub with a big dead blow mallet. Inspect the bearings and replace the grease seal before reassembling the hub onto the rear end.
First of course there are a couple of screws holding them on. I hammer with a flat face on the drum where it is backed up by the hub. After a while the blows produce little whiffs of rust and that is a sign that it is coming loose. Jerry's suggestion is the safest way. You are correct that it is very hard to find replacements.
1951 1 Ton Completed
Nix....I think you just pounded me on the head with a hammer. I completely forgot about the screws that hold them on. Talk about a good rap on the head to jog the memory. When the sun comes up and time allows, I will remove the screws and try again! I did get it to spin a little, but it's pretty tight. I figured it got seized up from sitting. I'll remove screws and try again before I dive any deeper. Brake lines are all removed. Prepping frame for sandblasting. But didn't want to blast until I knew I could roll it easily. I figure it is a brake adjuster that isn't aligned right.
