4 members (Bill Hanlon, Gray_Ghost, Otto Skorzeny, Robert Crandall), 160 guests, and 2 robots.
Topics128,162
Posts1,056,945
Members48,458
Junior Member
Junior Member
Hope this is the right forum for this question! On my truck, only the left side rearview mirror came from the factory. For added sense of security(and to keep from running over stuff on the blind side) I want to add a mirror on the right side. My question is: are the mounting holes the same distance in front of the door and the same height on the cowl as those on the left side? If not, what is the proper location---I can't find another truck in this part of Texas with a right side mirror to compare to. Thanks guys/gals. :confused:
"Age is only relative- - -It's just that some of us have more relatives than others"
The best way to approach it would be to look under the dash. You may need to pull out the glove box. Because of the location of the heater, I can't guarantee that they are in exactly the same spot.
Paint & Body Shop moderator
Junior Member
Junior Member
:confused: Hey, appreciate the rapid response there. Unfortunately, there is nothing outside or under the dash to give me a clue to the location. We've got her in the paint shop--ground the old paint down to bare metal and did not see any evidence of holes, dimples for holes, or anything. Trucks been in the family since it was new, and I know that it's never been molested to have the holes filled. So--back to square one. Thanks anyway!!
Goes on the cowl, half way between the edge of the door and the edge of the hood up near the top.
I would have someone hold it up and be in the drivers area and try to position and mark it that way.
The right mirror has quite the curve to the arm so you can see it thru the windshield.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
There is a TECH TIP on this topic that I followed when I insatlled a mirror on the right side of my '54.
Following the TECH TIP, I removed the carboard glove box and found two olbong holes in a backer plate that was already part of the cab. I drilled holes through the oblong holes in the backer plate and mounted the mirror.
I don't know about the mirror on the drivers side, but I imagine the same holds true.
To find the TECH TIP go to the Tech Tip page on this site. Scroll down a bit the the FAQ Page. Click on FAQ and you will see a "How Do I...'' section.
"How do I Install a rear view mirron on my AD truck is the 8th tech tip down.
Good luck
Junior Member
Junior Member
Thanks jfjbjr!!! I reckon I didn't <deleted> the inside quite far enough up to find that backer plate. That solves the mystery for me. Now I can go on to some of the other mysteries of the rebuild!
