2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#125471 04/11/2007 1:56 AM
I'm gonna be putting bear claw latches in my truck.
Can anyone tell me which to buy? On eBay, it looks like Autolock is the best, but I see "large" and "small" bear claw latches ... which is correct for our trucks?
Anyone know?
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#125472 04/11/2007 1:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
This may help you. It shows how I did the small latches on my 54. Send me a PM if you have any questions. I have seen some done with the large latch but in my experience there is not enough room inside the door for them.
http://www.picturetrail.com/gallery/view?p=999&gid=11601864&uid=2902753
#125473 04/11/2007 2:13 PM
Wow! What a *great* tutorial! You are a life-saver, man!
grin
Where did you buy your Autolock kit? Should I buy mine on eBay? Sometimes it looks like they are only selling the latches and not all the other parts.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#125474 04/11/2007 5:22 PM
Anonymous
Unregistered
Anonymous
Unregistered
I got mine off ebay. A quick search found auction # 260106374037 has the same ones that I used but I also bought the installation kit which made things a bit easier. The install kit will show up eventually on ebay as everything usually does that I need. Autoloc is the brand I used. If you want some pics of the final results I can take some. The install was pretty easy and figuring out how to keep the outside handle was the interesting part of the challenge. It is working fine for me.
#125475 04/11/2007 10:09 PM
I used the large. Just mke sure you get the install kit.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#125476 04/12/2007 3:27 AM
Thanks, guys. I'm having my truck painted this Spring and the painter is going to install them before paint.
I'll definitely be posting the final results.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#125477 04/14/2007 6:57 AM
I used small latches on my 55 3600. I shaved doors and used 78 lb pulls and door popers. if you do install them consider what I did. I put the latch in the door post and the bolt in the door, easy to do and no wires and holes in front door post or door.
#125478 04/14/2007 7:20 AM
However -- with the bolt in the door, instead of the latch, you can not use the door handles ... correct?
I like my door handles.
grin
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#125479 04/14/2007 11:37 AM
It's not me, but correct. You must use actuators and a remote.
#125480 04/14/2007 1:26 PM
Quote
grin
The stock door handles could be used to operate a microswitch inside the door to actuate the latches. This was the plan for a project truck that didn't happen.
Mar-Ktech
#125481 04/14/2007 3:06 PM
I don't like electric windows or doors ... one problem and you can't get in or out, you know?
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#125482 04/18/2007 11:20 PM
sorry for the delay in responce, been on the road. micro switch can be used with original handle but did not go that way. I installed a spring loaded rod from the latch up inside the cab above the sholder and attached a simple ball handle to it. works buy simply reaching up and pulling down. I also installed a cable pull outside and under cab in case of elec failure. I only use the popers to enter truck, and only then if the window is rolled up otherwise I reach in and pull down on the ball, works slick. I put arm rest on the door for comfort and to provide a way to close door as you enter the truck. hope this helps.
#125483 04/18/2007 11:34 PM
I could not find this url at first, It shows shaved doors and filler neck on 55 2nd and has the latch on post install. [URL=http://www.vanhalen-irc.com/pro55/body3.htm]
