| | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | 66 suburban, dark brown (don't have actual color name on hand) dash, I believe 10% gloss. The dash had the original paint on it, but I had to repair some cracks at the glove box corners and a couple of other minor things. I have since scuffed, cleaned and sprayed it with an etching primer from a rattle can. Do I need to do a better primer before color? This is not a show vehicle, just keeping it original. Thank you for your help | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I don't think a dark brown dash color is original. Is it?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | you don't really need etching primer over steel or old paint. But, to answer your question, a lot depends on what type of paint you are putting over the primer. Sometimes, if you use a different type of paint, it can crinkle or life the primer. If you get it smooth, and the paint lays down fine over it, you should be fine. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Bartamos, yes, the dark brown, pretty much the color of chocolate is the original dash color, which is also inside the glove compartment and also under the build sticker.
Mike: I have used an Omni single stage on the firewall, and was real happy with the outcome. As I mentioned in the previous post, I have read on the paint sheet that the dash paint was 10% gloss. I don't know if this can be done with Omni paint, but if so, that is what I would assume I would use. | | |
