8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | Can anyone share with me a part number for the differential cover gasket on a 54 Chevy 3100 half ton truck? I ordered 2 gaskets from Amazon that were suppose to fit and they didn't. I then ordered the gasket from classic parts which did fit but didn't seal. That gasket was as thick as tissue paper and it wasn't a surprise it didn't seal. I should have listened to my gut and not even tried it. The original gasket looked like it may have been cork. Anyone have a part number for something decent? I have put in oil pan gaskets in the past that were steel coated with rubber on both sides. I would love to find something like that for this application. Thanks | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Jonald , There's a GM NOS cork gasket on ebay . Go to ebay & in the search box..........type.........370245 The seller on ebay has a make an offer option . see PIC https://s26.postimg.org/810p1wf21/370245.jpgGeorge '54 3600
| | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | I will look into that thanks | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I believe the stock gasket for the rear housing cover was a thick gray paper, not cork. But I'm sure cork would work well. Keep in mind it's all in how you prepare the surfaces and gasket as to whether it leaks or not.
Here's NAPA:
FEL-PRO Gaskets PART #
FPG RDS5088
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
