1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#1254409 02/10/2018 1:55 PM
I saw new flywheels on Rockauto and Orielly's, Rockauto list them for 1954 261 engine. Do you know if that will fit on an 46 235? Is there a difference in the crank bolt pattern in the center.
I saw one was 4 bolt, the other 6 bolt mounting to the crank. Basiclay I'm repacing my 9 bolt 10.75 inch clutch with an 11" but I need a different flywheel. I've asked around for a 139 tooth 6 bolt, 11"
flywheel without success. I saw several new ones and want to ensure one will work before I purchase. Here is the link from Rockauto and Orielly's. Since the new ones are 168 tooth, I was going to
go ahead and switch my starter to 12V since I'm already running that way. Thanks
http://www.rockauto.com/en/moreinfo.php?pk=1384283&cc=1326484&jsn=8&jsn=8
https://www.oreillyauto.com/detail/...eel/nfw1007/4672027/1954/chevrolet/truck
1942-62 used the same bolt pattern.
However both flywheels you linked to only have one line-up dowel.
The flywheel you need will have three dowel holes.
My Blog
Thanks Dave,
Yes I see that now,
Dowels aren't forever- - - -they can be removed and replaced with short plugs to prevent oil leaks. If the bolt pattern, flywheel diameter, and ring gear tooth count matches up the flywheel should bolt on and work, but you might have to make your own timing marks when you assemble the engine. That's a simple process of finding top dead center and using a degree wheel to locate where to put advance/retard markings on either the flywheel or the front pulley. Parts don't care where they're put, as long as the guy installing them is a little bit smarter than the part he's installing.
I bought that same flywheel for my 261. It was over a year ago but from what I can recall it turned out to be a V8 flywheel that also had the wrong ring gear teeth, and I think that the bolt pattern was also a different diameter...so their listing was not correct. So not just a dowel pin issue to deal with there. I have seen old aluminum flywheels on eBay every once in a while for the 235- I have always been curious what it would be like driving a truck with one of those (probably not to pleasant?).
~ Dave
** lend-lease, I have the flywheel you are looking for. An orig. removed from a 1962 261. If interested send me a pm. ** I sent you a pm several days ago but it remains unread.
