2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#1254172 02/08/2018 10:02 AM
Looking for some advise on my trouble with my 1951 216 engine . For some reason I’m not getting much or most the time no wrapping noise come out my exhaust . I had manifold split. Intake was porcelined for look and exhaust manifold was jet coated. I’m am wondering where to begin with my trouble shooting . What would be most likely my issue with no wrap coming out of engine . I have timed engine rebuilt carb made sure my vacume advance moved on acceleration . And exhaust manifold seems not to be leaking air I also removed my glass pack and currently running strait pipes still very little wrap .any advice or past experiences would be appreciated
Facundo #1254185 02/08/2018 1:57 PM
Don't have a solution for your problem but I'll have to admit it is the first time i have heard of a six with straight pipes not having a "wrap". ohwell
Facundo #1254187 02/08/2018 2:09 PM
rap rap, not wrap wrap? headscratch
From the experts on producing such noises. cool
All I know is that my 261, with many carburetor setups and two different dual pipe/exhaust setups, made/makes too much noise. big_eek
Enough that a police officer pulled me over and told me that he had called me in because my rapping made him fearful that I would try to run him (I asked him if he would please write that on the ticket/summons). wink
Gleaned from the link above: if you are using original diameter pipes, you should expect reduced "rapping".
The 216 engine might also have only minimal rapping potential?
Facundo #1254218 02/08/2018 6:50 PM
H Online: Content
Have you tried playing different music for it? Maybe it's just not in the mood to rap to your choice of tunes!
Facundo #1254221 02/08/2018 7:13 PM
Joking aside, Jerry. If you wanted a 216 to "rap", would smaller diameter exhaust system pipes help?
High-pitched raps?
Facundo #1254223 02/08/2018 7:38 PM
H Online: Content
Smaller pipes will create higher velocity in the exhaust system, but the placement of the muffler(s) is the critical factor. Low-restriction mufflers close to the engine and a long tailpipe will allow for more resonance. I've got a cure for loud pipes- - - -it involves a good bench rest and an accurate rifle!
Facundo #1254225 02/08/2018 7:52 PM
Amen, Jerry
I have always thought that loud pipes are for people with certain character/physical traits that are inappropriate to specify in any forum here.
I hope you do not mind me including motorcycles.
Facundo #1254228 02/08/2018 8:04 PM
H Online: Content
My Honda Gold Wing 1100 is whisper-quiet, and it's going to stay that way. "Short man syndrome" is a real thing, according to a few public school psychologists I've worked with!
