| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | What is the best primer to use if you plan to finish with base coat clear coat? Does any standard gray primer work that can be used with enamel paint?
Any information would be helpful. Thanks, Scott
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Hello, I use PPG DP-40 Epoxy primer. This stuff is tough as nails and you can put anything over it given its a true epoxy. I have used this on cars, motorcycles, tractors, etc.. I have never had troubles with it. My 2cts Good Luck!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Many people say to use a primer from the same paint system/line as your finish paints. | | |
