Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, GMCJammer51), 41 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#125405 04/03/2007 12:27 PM
What is the best primer to use if you plan to finish with base coat clear coat? Does any standard gray primer work that can be used with enamel paint?
Any information would be helpful.
Scott
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#125406 04/03/2007 7:47 PM
Hello, I use PPG DP-40 Epoxy primer. This stuff is tough as nails and you can put anything over it given its a true epoxy. I have used this on cars, motorcycles, tractors, etc.. I have never had troubles with it. My 2cts Good Luck!
240,000 worker bees!
1960 Two ton Chevy
#125407 04/04/2007 4:14 AM
Many people say to use a primer from the same paint system/line as your finish paints.
