Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
I am looking for some recommendations (part numbers if possible ) on a master cylinder I can use for firewall mounted vacuum power drum/drum brakes on my 3800.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
V
VEW Offline
V Offline
I'm sure other bolters here have more experience with this than I do.
Not sure what size your bore needs to be, but here's one with 1-1/8":
master cylinder
~ Victor
1957 3100 - moved on
Y
yar Offline
Y Offline
Blind,
A very compact tandem master cylinder with a 1" bore is Bendix 11373. It even has a 1/8" pipe port on its bottom for a brake light switch.
Ray
