2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
A car buddy is trying to get an old friends ‘56 truck up and running as the friend is headed for the “big roundup” soon. It has a 6 volt negative ground system. In his stash of parts is this three lug battery. Has six fill caps in all so must be some kind of six molt battery. Anyone know of what application it might be for and/or how it was hooked up. It is Ford scripted and dry (no acid added). Thanks
H Online: Content
56 models came out with a 12V negative ground system. It sounds like you've got an old 6/12 battery, one that used a Ford-style starter solenoid in a series/parallel arrangement to start on 12, and run and charge on 6 volts. The last of the 6V systems was the 55 1st. series, at least if it's a Chevy. 56 Fords had a 12V positive ground system, the one and only year for that one. In 57, the whole automotive industry standardized electrical systems at 12V negative ground. Freightliner trucks and a few other commercial vehicles kept using positive ground systems through the mid-1960's.
Big Bolt Forum Moderator
6 fill caps would mean 12v battery, one cap per cell, each cell is 2v.
Mike
Crusing in the Passing Lane
The three 'lugs' might be the lead bars hooking the cells together. With 6 caps Mike says, 12 volts.
Ed
If you take a voltage reading it will probably show 6v from the center lug. I've never seen a 3 post battery, but have heard of putting in a screw in the center to run the rest of a car when converting to 12v.
Dennis
40 Chevy 1/2 ton
Found it. “Anitque Auto Batteries” under accessories. It is indeed a 12 volt battery with a 6 volt tap. Requires a 12 volt charging system. Used to run a 12 volt system with 6 volt accessories. Sound familiar to you guys needing to run 6 volt heater fans, gas gauges, etc.
As stated before, this battery is dry so no voltage readings could be taken. Thanks for the help.
