4 members (Otto Skorzeny, WICruiser, dwreills, 78buckshot), 45 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#1253462 02/02/2018 12:11 AM
Hey Gents,
I want to replace my 10.75 9 bolt clutch with an 11" 6 bolt. What flywheel do I need? My truck is still using a 6 volt starter with original flywheel.
I can find 11" clutch kits all day long for under $100 as compared to a fortune for 10.75 pieces. My truck is a 46 Chevy 1.5 ton.
Any help would be appreciated.
Crusing in the Passing Lane
Find someone local to drill and tap a new clutch bolt pattern on your flywheel, first get a new or used clutch and disc to get the fit and pattern from. A drill press is probably not accurate enough.
Ed
